Is it possible to print wirelessly with the PIXMA G2270
shar28092
United States, PIXMA G2270, Windows 11 on a 2023 HP Envy. I do not believe this printer can be operated wirelessly. Am I wrong?
The printer operates without difficulty, wired to the computer. It shows up in the computer's Settings, under Bluetooth & devices, Printers & scanners, as "Canon G2070 series". So far, so good.
The printer is physically located in the same room, just a few  feet away, and should be able to "see" the network as easily as the computer does.
I have played around with printer's very few buttons, and poked around the Canon site, YouTube, and the user's manual, trying to buy a clue.  I have tried approaching the setup from the computer, using its Help functions.Everything calls for the existence of buttons and menu options that this little device does not have.
Appreciate your thoughts and patience.
Stephen
Moderator
Moderator
Hey there!
You're correct in that this unit is USB only.
The printer's page is HERE.
on the right side are the key functions:
I hope this helps!
2 REPLIES 2
Stephen
Moderator
Moderator
Hey there!
I hope this helps!
shar28092
Thank you very much for your swift response.
