06-01-2020 01:53 PM
Hello!
We have 5 new computers for which I'm trying to install the drivers for the scanning capability, but it won't install.
I keep getting the following error:
"you do not have sufficient privileges to install the program. Log on again with administrator privileges"
All 5 users are administrators.
I've right clicked on the install folder and chose 'run as admin'.
I've done the same to the actual driver install file.
I've checked security measures and nothing is blocked.
I can print to that printer.
The function we need is to scan from the machine to a specific folder.
It's currently set up from the 'old' computers to do that.
These are new HP laptops with Win 10 business version 1909 build 18363.836
The printer is the MF 414DW.
Cheers,
Brian
11-08-2021 01:09 PM
A new computer, with Azure AD and I can't install the driver. Canon, please, solution for this bug!!!!!!!
02-07-2022 02:53 PM - edited 02-07-2022 03:54 PM
I can confirm that this is a problem with Azure AD joined devices. Canon's installer is not compatible with Azure AD permissions. The solution as outlined above is to create a local admin account to install from. A lot of unnecessary trouble because Canon hasn't fixed their software. 😫
02-14-2022 08:32 AM
I have the same problem with my local AD.
Printer Canon 446x.
05-12-2022 04:31 PM
I have the exact problem installing MF4890dw. The only way I can get the driver to install is login as a LOCAL administrator account which I had to enable. None other local account nor Azure AD accounts work. Very annoying.
05-30-2022 09:16 AM
I am using a MF642cdw and enabling a local user account does work to install the driver but it brings up a bigger question: does Canon even listen to it's users?
Seriously Canon, it's May 30th 2022 and it is still an issue. This issue has been open since June 1st 2020 - That is 2 years ago. It is really annoying as an SysAdmin to have to install this under a local admin account when every other printer manufacturer does not seem to have any issues. Canon has great product's but they are hampered by a bad driver installer.
09-06-2022 09:21 AM
This is an unacceptable issue caused entirely by incompetent programmers that can't even write an installation procedure. Unfortunately, it is the least of the problems that have made my MF743CDW the worst printer I have ever owned. I will never buy another Canon printer.
01-10-2023 09:14 AM
It's definitely a Canon issue. No question about it. Given how inadequate Canon support is and has been for 20+ years, it's not surprising they point the fingers at others, much like IT companies did back in the 1990's. Lazy arses.
10-20-2023 08:04 PM
I can verify that the above instructions work.
Basically, create a new account and make that Administrator.
Login as that additional Administrator-enabled account and run the MF4880dw driver installer.
Setup the printer via "Network Connection" instead of "USB". (You don't need to make the printer a "Shared Printer")
Log out or switch User Accounts to the original account. You should see the printers set up.
10-20-2023 08:35 PM - edited 10-20-2023 08:44 PM
Yeah, unfortunately this didn't work for me with the MF4880dw drivers on Windows 11 Pro. (Azure AD joined) I'm logged into my Windows 11 laptop with Active Directory creds and I did all the same stuff everyone else has probably done.
They all resulted in the "You do not have sufficient privileges to install the program. Logon again with Administrator privileges."
Curiously, "dcfitz"'s technique of creating another completely separate account (local, Microsoft account, whatever), granting it Administrator privileges, logging into that on the laptop, installing the drivers with a "Network Connection" (where it miraculously works) and then switching back to my AD credentials-based profile on the machine worked. All the installed/discovered network printers showed up in both accounts.
The issue appears to be the 3rd party installer that Canon used: It looks like a version of InstallShield from the Cretaceous era of personal computer (~2005? :-)) & it looks like Canon used the default installer template. The installer could easily be stepped up & reassembled with Flexera's newer InstallShield 2021 at the very least to avoid this rights-elevation problem for ring 0 stuff but I don't think there's any incentive to do so... given that this printer is 10 years old. (2011-2012)
11-02-2023 08:55 AM - edited 11-02-2023 08:56 AM
@kurtsh wrote:The issue appears to be the 3rd party installer that Canon used: It looks like a version of InstallShield from the Cretaceous era of personal computer (~2005? :-)) & it looks like Canon used the default installer template. The installer could easily be stepped up & reassembled with Flexera's newer InstallShield 2021 at the very least to avoid this rights-elevation problem for ring 0 stuff but I don't think there's any incentive to do so... given that this printer is 10 years old. (2011-2012)
@kurtsh Great analysis on this issue.
However, I won't let Canon off the hook because this issue impacts printers that are still for sale (MF642CDW in my case), that should be incentive enough to support your customers and upgrade the installer.
On top of that Microsoft is actively trying to nerf local accounts in newer versions of windows. Does that mean that this local admin method will eventually not work either? Come on Canon, the user community figured it out and provided the fix. Please update your installer!
