06-01-2020 01:53 PM
Hello!
We have 5 new computers for which I'm trying to install the drivers for the scanning capability, but it won't install.
I keep getting the following error:
"you do not have sufficient privileges to install the program. Log on again with administrator privileges"
All 5 users are administrators.
I've right clicked on the install folder and chose 'run as admin'.
I've done the same to the actual driver install file.
I've checked security measures and nothing is blocked.
I can print to that printer.
The function we need is to scan from the machine to a specific folder.
It's currently set up from the 'old' computers to do that.
These are new HP laptops with Win 10 business version 1909 build 18363.836
The printer is the MF 414DW.
Cheers,
Brian
01-08-2021 10:45 AM
I had the exact same problem and found only one way to fix it. It just takes a few minutes.
-Go to Manage Your Account>Other Users
-On the right, click on Add someone else to this PC
-Select a new log on and then make sure you grant it Administrator Privileges (You may have to create it and then go to Modify and grant the Admin).
-Restart you computer and log on with that ID.
-Run the Software and select "Shared Printer".
Restart with you original log-on and you should be able to scan to it.
You can then go in and delete the new Log-on you created and the printer will still scan.
The above looks harder than it is...it is really quite easy.
06-02-2020 01:29 PM
Hi keebcanon.
The first account on a Windows computer is typically limited in power, even though it will commonly be listed as "Administrator." Additionally, as work computers, they may be pre-setup to give authority to a networked IT or Admin account in the workgroup. There is nothing Canon-side that can preempt administrative privileges or lack thereof.
06-03-2020 11:18 AM
Thanks Darius. I appreciate you taking the time to answer.
I'll follow up with our IT person. I'm under the impression that this admin account is the full deal, but I could be wrong.
I'll post back with any results we may have for anyone else possibly encountering this issue in the future.
Cheers,
Brian
01-08-2021 10:45 AM
01-31-2021 05:32 PM
"Nothing Canon can do" response is wholly inadequate and unacceptable. I bought a Cano imageCLASS MF445DW and cannot install the MF Drivers though I am the Administrator, the 1st account on this W 10 Pro 64-bit Dell Laptop. There is no workgroup, no IT support - it's my personal and work laptop. Tomorrow (Mon. Feb. 1) if Canon Tech Support doesn't fix ir pronto, I'll send it back for a full refund. Period.
01-31-2021 07:56 PM
05-13-2021 07:24 AM
07-18-2021 12:22 PM
"There is nothing Canon-side that can preempt administrative privileges or lack thereof."
I think the problem has been misidentified and thus, incorrect courses of action are suggested. It isn't a lack of administrative privileges as most people I see looking for help are indeed administrators. I'm a domain admin and I can't do it.
Canon has made a poor installer with obscure requirements that no other manufacturer has.
07-29-2021 08:26 PM
09-09-2021 05:04 PM
Azure AD joined machine, user accounts on the machine are Administrator and Global Administrator and none of these accounts can install the MF642cdw, MF743cdw driver packages.
This is unacceptable! Canon blames Microsoft Permissions and over at Microsoft they blame Canon installers!
I personally believe this to be a CANON issue as the administrative permissions are properly set on over 200 machines in the organization!
You cannot expect an IT Admin to manually create local accounts for 200 users just to install a printer driver! That is unacceptable Canon!
Every driver from every other manufacturer works with Azure AD joined machines. Yet Canon wants to blame the permissions?
If you choose the USB option it has no problem installing the driver. Yet it obviously stops when it cannot locate a USB-connected device.
When you choose the Network option it is supposed to open up holes in the firewall to allow the driver to communicate with the printer yet stops you at the error message "Insufficient privileges to install Canon MFxxxCdw driver.
Please get this fixed as it is truly a problematic issue! It is obvious there are many people trying to get this to work and "RUN AS ADMINISTRATOR" should work yet doesn't. Run as an alternate user should work yet it doesn't!
We are not dealing with local accounts we are dealing with Corporate machines joined to AZURE AD
