Imageclass MF455dw Print Spooler Error Windows 11
jjninin
Successfully installed MF455dw laser printer with a wireless connection for multiple devices.  Scan works fine.  However, while  printing on my Dell Insperion 14 5000 laptop, I get sporadic printer errors, with the document stuck in the Print Queue.  Often, the document error will clear in 10 or 15 minutes, and will then print successfully.  Note all other devices work fine: iphones, ipads, and chromebook all work flawlessly.  Is it something with the Windows spooler?  Is there an update I am not seeing in the software updates?  Thanks in advance!!
1 REPLY 1
jjninin
Original poster here.  I should also mention that I have updated the firmware and re-installed everything twice.
