ImageCLASS MF453dw Bonjour/mDNS not working?
ruthenium
I have an ImageCLASS MF453dw multifunction B/W printer at home. It looks like after the latest firmware update Bonjour/mDNS stopped working. I am looking at the services being advertised over mDNS on the printer's subnet and don't see them any longer. Has anyone here observed the same or maybe even has a solution?
Relevant configuration on the printer:
  • Wired Ethernet connection.
  • Network Settings --> IPv4 Settings --> mDNS Settings --> Use mDNS: On
  • Network Settings --> IPv6 Settings: Off
  • Network Settings --> AirPrint Settings: On
Troubleshooting steps taken:
  • Rebooted printer.
  • Toggled the relevant settings Off/On.
  • Reset network settings to factory.
  • Connected computer directly to a printer with a cable and used dns-sd (macOS) and avahi-browse (Linux) to monitor mDNS advertisements.
  • Tried to capture packets on port 5353/udp.
Results:
  • The printer does not advertise services over mDNS.
  • The printer is not discoverable by devices if it is in the sleep mode.
  • The printer is discoverable when when it is online, probably using SDP or some other discovery protocol.
  • Running the scanner software does not wake up the printer from sleep any longer.
0 REPLIES 0
