G3202 not connecting
ptr1
I cannot get the Pixma G3202 to connect to wifi.  Also, when I connect using a usb cable, it says the printer is busy performing an operation.  Is there a solution (that does not involve a sledgehammer)?
3 REPLIES 3
ArthurJ
I recommend reaching out to Canon support for this issue. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
RR2022
I'm having the same issue. Did you ever get it resolved?
I've done that and there still is not an option to contact anyone.
