Error "Not able to open port.: 0000" while installing E560 on DELL Inspiron 15 AMD Ryzen, Windows 11
jnk
While installing the printer, the error Not able to open port.: 0000 is displayed and the installation aborts.
Printer Scanner E560
This is on Windows 11, DELL Inspiron 15 laptop
Please advise,
2 REPLIES 2
The Canon e560 is not a device intended for sale in the United States.  It appears to be supported in the Asia and India markets.  The issue you are having appears to be related to your Windows installation and not to your Canon product.
After performing a quick search the following recommendations were made.
Remove any failed instances of the printer
Remove any software or drivers related to a failed install
Temporarily remove other installed printers that may be conflicting with this installation
Restart the system and attempt a fresh install of the device
If connecting via USB do not connect the printer until prompted by the installation utility
Connect the printer directly to an available USB port, and not through a hub or adapter
Perform SFC /scannow from an elevated command prompt to verify and repair any corrupt system files
Use a registry cleaning utility to remove any orphaned entries that might interfere with the installation
Note, the printer is designed to be installed on systems based on Intel or AMD architecture.  ARM based systems are not supported.
If you need more help:
In order to receive support in your country or region please visit the Canon Global website.  Choose the country where you live to see your support options.
https://global.canon/en/support/
Ron
Moderator
Moderator
Hi jnk,
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market. The PIXMA E560 isn't sold or supported by our team here at Canon USA.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
