CaptureOnTouch Pro - Add Spaces to Naming
MockCat
I have a scan profile which I would like to systematically name, as seen in the image below, except I would like to be able to add spaces between Scanning Name and Document Name, as well as between Document Name and Detection1. If I try to add another Character String with a single space(or any number of spaces) without any other characters on either side of the space(s), the space(s) are removed. Same goes for if I add spaces at the beginning or end of the Shortcut Name.
Before anyone suggests that I add a space to the beginning and end of Document Name, I am also using Document Name to create a folder. Windows has trouble with documents having spaces at the beginning or end.
Is there any way I can specify a space character? I understand the trouble it can cause within file naming conventions if used improperly, but in this situation those issues would not occur.
1 REPLY 1
hm2
Canon is trash about answering questions on their forum. It's a simple thing they could do, and they don't bother to do it.
