10-04-2024
04:43 PM
05:59 PM
Tiffany
Literally worst experience ever. Printer continuously falls off network. Go through the process, get it on network (pc, iPhone, etc). Print successfully. Next time i want to print it’s not on the network. Standard on/off doesn’t work (if that did it would just be annoying). Is canon doing anything to patch this printers firmware or offering rebates. Literally worst printer ever. Last canon printer lasted 10 years and was perfect, available for printing and printed wonderfully.
10-04-2024 05:57 PM
Welcome to the forum!
So that the Community can help you better, let us know which version of Windows or macOS you are using? How are you connecting? Is there an exact error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
10-04-2024 06:52 PM
iPhone 18.0 and 18.1 OS install via app over WiFi.
windows 11 w latest patch.
in both cases was able to install, was able to print test page and was able to air print. Then printer not found at next print, less than 24 hours later.
10-10-2024 08:24 AM
windows 11
was able to install, was able to print test page and was able to print from cpu,Then printer not found at next print, less than 24 hours later. are there any solution to this problem yet ?.
