04-14-2025
10:57 AM
08:49 AM
Hello Everybody
The Windows 11 Drivers for Canon i-SENSYS MF237w is not working. When I get the option to detect network printer it doenst pick up Printer. I can ping printer and install manually. I can access printer web interface. The problem is I need to run the Canon driver software to install the scan software as well. If I try to install scan software I get a error.
04-22-2025 10:24 AM
I called Canon South Africa to help resolve problem. Here is what they did
Reset printer, change IP Address. Uninstalled the drivers completely from the laptop, did the new installation and used the new IP address. Resolved
04-14-2025 12:47 PM
04-16-2025 08:24 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
04-16-2025 08:47 AM
Someone else reported a workaround for this in a similar situation. He assigned a static IP for his printer on the network and then used the specify IP address which allowed him to add the printer and install the software successfully under Windows 11.
04-22-2025 10:24 AM
07-29-2026 09:14 AM
Hello,
For the past 3–4 days, I have been troubleshooting the scanning functionality of the Canon MF237w on 6–7 different computers.
Eventually, I found my own solution.
Instead of installing MF230SeriesMFDriverV5202WPEN, I installed MF230SeriesMFDriverV520WPEN.exe, and everything started working correctly.
Download link for MF230SeriesMFDriverV520WPEN.exe:
https://asia.canon/en/support/0100772501?model=1418C031
Below are the troubleshooting steps I tried before finding the solution.
I tested the solutions mentioned in the following Canon Community and Microsoft forum posts:
Unfortunately, none of the following methods resolved the issue:
