04-05-2024 07:06 PM
I have a Canon G7020 Printer. Everything was working fine, then it went offline. I reset it and reconnected it to the network. Now I'm trying to add it as a printer/scanner on my macbook, but it won't find it. When I run the Canon IJSetup software, it finds it but there isn't an option for Airprint in the dropdown for the driver. How do I get the printer setup again?
04-06-2024 12:08 AM
See if this helps. Log into your router's admin portal. Confirm the IP address the router has assigned to the printer. Reserve this IP address so the router always uses this IP for the printer. Add the printer to your Mac as an IP printer. Example, mine is 192.168.1.99
Router - Reserve IP
