Canon TS3522 Driver Not Found MacOS?
brookeanne223
Hello,
I'm trying to set up and add my printer to my MACOs device. Every time I go to add the printer, I select auto under use, however it doesn't auto select a driver. I can't find AirPrint anywhere under use like the setup says. Please help!
2 REPLIES 2
Moderator
Moderator
Hi, brookeanne223!
So that the Community can help you better, we need to know exactly which version of macOS is running on your Mac. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
jenncarson
I have a similar problem which is that I am unable to get the Canon MG2522 Pixma to show up in the add function of adding printers in my Mac book Pro. I'm running OS -High Sierra 10.13.6
It should be noted There is just nothing there when I click on +, and I have the Usb plugged in to the printer, and of course to the Mac - so it should not need to be added with any IP address. The installation worked sucessfully when I  installed drivers.....
help please!
