Canon Printer Not Found ??
NorPlan2
Have a Canon MX 452 Printer , The Objective is to Connect it to my HP Laptop Wirelessly..  Somehow between Canon & HP Latop to connect is lost in the Translation if you will ??  Went on YouTube and since I don't have the Disc was given this Canon website to Setup Printer (canon.com/ijsetup) My MX452 is Not Listed (??) Any ideas or have I reached the end of the road with is Printer ??
2 REPLIES 2
This is what I found on Canon's Support Portal:
Support | MX Series - Inkjet | PIXMA MX452 | Canon USA
and
Abigale
Print off a config page or a network page from the internal settings on your printer. This should provide you with an IP address to verify it is connecting to the network. Then you can run a ping command from a CMD session and verify that your PC can speak with it. If you get ping replies, use the add printer function and type that IP address into the requested fields.
My CC Pay
