Canon PIXMA TS3522 unable to connect to WiFi or Android Phone
tbird1234
I obtained this printer from a person who had been using it successfully. I am trying to get it to connect to my wifi. Is this printer able to print from an Android smart phone? If not how about a Chromebook?
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know which version of Windows or macOS are you using? Is there an error message? Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
Greetings ,
Yes, you can print from an Android device to the TS3522.
The app you need is called Canon Print.  It's available on Google Play.
Here is a link to the support portal for your device.
https://www.usa.canon.com/support/p/pixma-ts3522-wireless-all-in-one-printer
It has links for drivers as well as the Canon print app for Android.  It also has set up an installation instructions for Windows, Mac, or your mobile device
