Canon ImageCLASS MF269dw - airprint problems
charvie
Hi
I am following the Using AirPrint guide in the manual p274 where it says:
1 Start the Remote UI and log in to System Manager Mode. Starting Remote
UI(P. 336)
2 Click [Settings/Registration] on the Portal page. Remote UI Screen(P. 337)
● If you are using a mobile device, such as an iPad, iPhone, or iPod touch, read "click" as "tap" in this section.
3 Select [Network Settings] [AirPrint Settings].
I can start the Remote UI ok but my Network Settings doesn't have an AirPrint settings!  How do I go about connecting my iPhone and Mac to the printer?
Cheers
Chris
1 REPLY 1
Hector
Hello Charvie,
If you do not see the option for airprint, you can try updating the printer firmware using the steps in the link provided HERE. Once the firmware has been updated, you can go back into the remote UI and then you can select Settings/Registration. Once you are back int that section, you should now see a check box to use airprint.
Friends and Family
