11-26-2012 12:48 PM
Can I setup my canon printer with my phone hotspot and an Ipad?
12-04-2012 09:46 AM
Hello Cdyoung.
Unfortunately, a standard WiFi router would be needed in order to be able to use the MG3220 wirelessly. We cannot support the unit with a mobile hot spot or air card. If you do not have a WPS-ready router, the wireless setup can be performed with a standard Windows or Mac OSX computer.
02-04-2013 08:42 PM
How does one go about setting up this printer above even with a router (specifically a U-verse router/modem built in deal)? The instructions weren't very clear that came with the printer, but it looks like I've got to have a base computer running and plugged into the printer for it to work wirelessly? Is this the case?
Thanks.
02-05-2013 10:19 PM
Hi JonathanM98,
Assuming you have the CD that came with the printer, all you would have to do is insert the CD and perform the Easy Install. Follow the instructions on the screen and when prompted, specify that you want to set up the wireless using the connection cable. It will ask you to temporarily connect the printer to the computer via USB so that it can send the information about your wireless network to the printer over that USB connection, and when it's done and it has verified that the connnection is active, it will instruct you to disconnect the USB cable and from that point on it will be wireless.
