05-23-2024 04:10 PM
I have downloaded and added ICC profiles for a Hahnemuhle sampler pack. For the life of me, I cannot get them to show up in Professional Print and Layout Manager. They show up just fine in Capture One’s print dialog, but not PP&L.
If I try adding them via the Media Configuration Tool, I can locate the profiles, but they, as well as the already installed Canon paper profiles are grayed out and unavailable.
The profiles live in Library-> ColorSync and I also copied them to Users->(my name)-> Library-> Colorsync
The details: MacOS Sonoma 14.5, Pro-300 printer, most current version of PP&L. Under System Settings->printers & scanners the Pro-300 shows up as Canon Pro-300 series-AirPrint, with no option to change that.
05-23-2024 04:22 PM
Hey there!
Welcome to the Canon Community Forums!
So that everyone is on the same page, can you please ensure you've installed the Canon drivers & software from the following page: https://canon.us/PRO300setup
Even if you have in the past, that page will re-download and re-install the most up-to-date drivers so you can take advantage of all of the printer's features. Please let us know if you've done that and still need help.
If this is an urgent support need, give support a call at 800-OK-CANON (800-652-2666), and they'll help you get to the bottom of whatever might be causing the problem!
05-23-2024 05:13 PM
Yup, been there, done that. Also ripped out and reinstalled PP&LM.
04-27-2025 04:19 PM
I've got the same problem. Anyone find a solution?
05-22-2025 10:56 AM
Surely this must be possible. The original question from almost a year ago is still unanswered. Recommending updating software and s not a solution.
please can someone help.
