06-07-2013 01:55 PM
I tried suggestion on line and even removed, cleaned , dried and reinstall ed the print head - no luck.
03-04-2018 08:33 PM
1. Turn OFF Power
2. Open the print head bay (as though you were about to change inks.
3. Turn ON power
4. Wait for print carriage to start moving to the left and let it go past half way
5. Before print carriage reaches left hand side (but after going halfway across) shut the cover.
6. Leave the Printer turned on.
Some say it may take a few times, but it worked for me on the first try.
I had already tried the directions here to no avail and had also cleaned the printer head.
02-28-2019 02:50 PM - edited 02-28-2019 02:51 PM
Can confirm ewil99's fix still works! Thanks!
06-15-2020 10:24 PM
It worked!
10-23-2020 05:05 PM
06-10-2021 02:58 PM - edited 06-10-2021 02:59 PM
Ewil99'ss- June 10th 2021 you saved me from buying a new printer. Been working on this for a week before I found your solution which worked first time!!!!! THANK YOU!!!!
06-10-2021 03:00 PM
08-08-2022 11:56 PM
I did this step by step on my printer then it just turned off and I can't get it to turn back on. Help
05-09-2024 12:46 AM
tried today on MG5250, worked on second attempt!
BRILLIANT SOLUTION!
10-16-2021 10:36 AM
ewil99's solution worked for me, the first time I tried it. Terrific. Thanks!
