05-02-2024
02:06 PM
10:43 AM
I have a MF4350 printer that was working properly in the past, and then all of a sudden, it started printing out a blank page after EVERY page that I print and then pauses after each page with the prompt: "Use current size" and I'm given the option to select Yes or No. But no matter which option I choose, it doesn't function properly. I end up having to turn off and on the printer after each page that I print to clear this error. It's super aggravating! I've been searching all over for a solution, and tried reinstalling the driver, setting printer settings to the default, and nothing seems to fix it. Any guidance would be appreciated.
07-17-2024 02:10 PM
I have the exact same problem which also only started happening recently. Could someone from Canon respond?
04-02-2025 10:34 AM
Hello,
If you get a message on the printer and you have to confirm the paper size to start the printing, it usually means the incorrect printer driver is being used. You can try reinstalling the current version of the driver from our site using the link HERE. It will be at the top of the list and will have Recommended written above it.
You can also try confirming the paper settings on the printer to make sure they match the paper size and type that you are selecting on the computer.
