07-18-2013 10:12 AM
When I connected my new XS500 IS to my MacBook pro, the Canon device box opened, then gave the "no camera found" message. The camera works with my old MacBook (Snow Leopard) and my old Canon GS7 works perfectly with both computers. I just installed the software, so believe the updates have been done. I removed the memory chip and installed in the Pro and the pictures downloaded fine. Any suggestions?
07-21-2013 02:35 AM - edited 07-21-2013 02:42 AM
Try this. Connect your camera to your Macbook and turn it on. Next, go to your applications list and open Image Capture. On the left side of your screen you should see a list of any devices you have connected to your Mac, and your camera should be listed there. Select your camera from the list, and from there you should be able to transfer images, etc., from your camera, although you may have to tweak the application's settings.
07-21-2013 10:06 AM
Hi nightwings!
Please download the update to CameraWindow DC 8.9.1 and ImageBrowser EX 1.1.0 from the Canon USA website. The link below will take you to the download page:
This will ensure that the software is up to date. CameraWindow should now be able to connect to both cameras.
07-21-2013 10:06 AM
Hi nightwings!
07-21-2013 11:31 AM
Yes, that did work for downloading, so I don't have to remove the SD chip and load it from it.
Thanks
07-21-2013 11:35 AM
Thanks, the update did solve the problem and the program is starting up as it should, although the device still does not show up in my "Finder" or on my desk top.
Thanks!
07-21-2013 08:02 PM - edited 07-21-2013 08:03 PM
Again, try selecting your camera as a device in Image Capture. It's not a guaranteed solution, but based on past experience it should work.
07-21-2013 09:25 PM
Yes, that first previous reply was for you. I tried it first and it worked with no problem.
Thanks again,
Matt
07-22-2013 02:47 AM
Gotcha, and de nada....
