03-14-2013 01:35 PM
hi
2 questions
how do i take a movie without any sound
also, how can i edit this movie?
i want to take out unwanted background space. sort of like cropping down the movie
thanks in advance
03-18-2013 04:55 PM
Hi Omid70,
The microphone (sound recording level) of the movie, sound memos, sound recorder and wind filter setting can be changed.
1. Select [Audio] from the settings menu and press the <FUNC./SET> button.
2. Set the microphone level by selecting [Mic Level] and use the
button to select [Auto] or [Manual].
- When in [Manual] mode, press the
button then set the sound recording level (recording volume) with the
buttons.
displays on the LCD monitor during recording. In this case, you;d just set the recording level to zero.
You may delete audio in ZoomBrowser using the "Edit" button. Choose that, then choose "Edit Movies". Under Edit Movies, choose the 4th step: "Set Audio".
Click the [Set Audio] radio button.
Click the [Add Audio] button.
The [Add Audio] dialog box displays.
Select an audio file and click the [Open] button, and the dialog box closes.
REFERENCE
Audio is added to the storyboard.
Deleting Audio
1. Use the mouse to select the audio you wish to delete from the audio displayed on the storyboard.
2. Click the
[Delete] button on the storyboard.
Advanced AudioSettings
1. Use the mouse to select the audio or image for which you wish to set the advanced audio settings.
- You can select either an audio file or an image/movie with audio.
2. Click the [Advanced Settings] button.
The [Advanced Audio Settings] dialog box displays.
3. You can set advanced audio settings through the [Advanced Audio Settings] dialog box such as fading in or fading out and duration of audio.
4. Click [OK] when complete.
