01-11-2023 11:11 PM
I keep getting an error on my camera that my memory card is locked. I checked the switch on the card to make sure it is in the unlocked position, I cleaned the card and tried to format it also but none of the above worked.
Does anybody know how to fix the problem and get rid of the memory locked message.
01-12-2023 06:32 AM
Are you using a full-sized SD card? Or a micro-sized SD card with an adapter?
01-12-2023 06:40 AM
full size
01-12-2023 07:19 AM
In the card slot on the camera, is there any corrosion you can see or damage to any of the pins? For cleaning, others will most likely be able to offer suggestions. If pins are bent/broken though, I'd suggest sending in for a repair.
01-12-2023 03:24 PM - edited 01-12-2023 03:26 PM
Have you tried other SD cards?
What size SD card are you using?
01-12-2023 03:28 PM
yes I have
32G SD card. and the memory card I have that will not work in my camera does work in other cameras
