memory card locked error on sx620
bubby
I keep getting an error on my camera that my memory card is locked. I checked the switch on the card to make sure it is in the unlocked position, I cleaned the card and tried to format it also but none of the above worked.
Does anybody know how to fix the problem and get rid of the memory locked message.
5 REPLIES 5
rs-eos
Are you using a full-sized SD card? Or a micro-sized SD card with an adapter?
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
bubby
full size
In the card slot on the camera, is there any corrosion you can see or damage to any of the pins?  For cleaning, others will most likely be able to offer suggestions.  If pins are bent/broken though, I'd suggest sending in for a repair.
Ricky
normadel
Whiz
Have you tried other SD cards?
What size SD card are you using?
yes I have
32G SD card.  and the memory card I have that will not work in my camera does work in other cameras
08/18/2023: Canon EOS R5 C training series is released.
CR-N700 - Version 1.2.0
CR-N500 - Version 1.3.0
CR-N300 - Version 1.3.0
CR-X300 - Version 1.1.0
06/30/2023: New firmware version 1.0.5.1 is available for EOS-R5 C
EOS R6 - Version 1.8.2
EOS R7 - Version 1.3.1
EOS Rebel T7 - Version 1.2.0
EOS R5 - Version 1.8.1
