‎02-26-2019 06:25 PM
Hello,
I have a Powershot SD200 and bough a new Sandisk 64GB memory card. When inserting it, I get a memory card error message. When I go into the Tools menu, the Format function is not available (highlighted).
Could the problem be that it's an SDXC card, since this is an older camera? or is it that I need a card smaller than 64GB? Or both?
Thanks,
Trang
‎02-26-2019 09:19 PM - edited ‎02-26-2019 09:28 PM
The SD200 can only use standard SD cards and only to a maximum 2GB capacity.
Supported memory card types, and maximum storage capacities.
‎02-26-2019 06:51 PM
Your camera might only be capable of using a 512 MB card and just a plain old SD card back in the day. I would say first it is the type of card you tried and then maybe second the capacity.
‎02-26-2019 08:36 PM
Thanks for the advice. I will try a regular SD card.
Thank you. That's super helpful. I suspected I needed something smaller and different type of card, but wasn't sure what parameters.
