06-25-2015 12:10 PM
I just upgraded from a s90 to a G1x Mark II. In manual mode the lens ring is what sets the aperature,shutter speed ISO etc. Is there a way to set the 'function ring' on the back of the camera to take up some of these functions?
On the s90 the 'function ring' did these tasks while the lens ring was for the zoom.
Thanks.
06-28-2015 12:03 AM
06-30-2015 12:54 PM
AlanBrownArt,
The PowerShot G1X Mark II does not have the same Stitch Assist mode some of the older models had. All this mode did in the past was help you to line up the edges of each image taken in the sequence. All of the stitching together of the images was done using software after the images were downloaded, which is still the case. All you need to do is take each image in the sequence overlapping each by about 1/4 to 1/2 of the image, then use the software to assemble them into a panoramic image.
06-28-2015 12:03 AM
06-28-2015 11:31 AM
Thanks! I couldn't find it in the manual. I'll take a look.
06-29-2015 09:21 AM
While were still on questions about the G1x Mark II...
I heard that the G1x Mark II does panorama shots but I couldn't find the function either on the camera or the manual.
Do you know anything about that?
Thanks! Btw, I love the camera, the photos are beautiful.
06-30-2015 12:54 PM
AlanBrownArt,
