02-24-2014 04:52 PM
Can the Canon Powershot ELPH 100 HS be wall charged through the USB (USB A/Mini B) cable as some phones can? It was telling me to charge the battery. It didnt seem to be charging connected to the PC. I used a Motorola Droid USB wall charger and connected it to the camera with the USB A/Mini B cable. I briefly turned it on and saw the battery charge icon charging on the screen and turned it off. Several hours later, it wont turn on. Have I done the unthinkable and fried it??
02-24-2014 07:23 PM
You likely drained the battery. Remove it from the camera & use the charger supplied with the camera. The USB port isn't a charging connector.
02-25-2014 11:15 PM
@cicopo wrote:You likely drained the battery. Remove it from the camera & use the charger supplied with the camera. The USB port isn't a charging connector.
Apparently, thats what I did, drain the battery. I put that battery in the supplied charger, it charged and the camera is fine.
<whew> My GF wouldve kicked my butt if I cooked her camera.
I wonder why the camera wouId turn on and display the battery charging icon on the when I first connected it to the wall charger. No matter. Thanks
02-24-2014 07:23 PM
02-25-2014 06:09 AM - edited 02-25-2014 06:17 AM
You could try ensuring the battery contacts are clean and not tarnished, try wiping them with a lint free cloth.
I would have thought a discharged battery would have been able to recharged from ANY power source, a usb dc source is usually 5 Volts dc being above the battery 'terminal voltage'.
Try another battery, batteeries do wear out especially rechargeable ones.
Dave
02-25-2014 11:15 PM
