Why don't my 67mm filters fit on my SX50 lens? The manual says they should.
toomanyboats
4 REPLIES 4
tnicoson
Enthusiast
Even though the SX line of PowerShots use 67mm filters, the threads do not match, so an adapter is still required.
See here for adapter info:
http://shop.usa.canon.com/shop/en/catalog/filter-adapter-fa-dc67a
Regards,
Ted
@tnicoson wrote:
"... the threads do not match, so an adapter is still required."
 Ted? Where on the SX50 are these threads that don't "match"?
Cheers
Grazie
Sorry, Grazie,
My error !  I had over-simplified my original reply.
When I first got my SX40, I had a circular polarizor and a UV filter from another camera that looked like they would screw into the end of the SX40's lens tube, so I tried very gently, but the threads did not quite "match".  I finally realized that those were not threads in the SX40's lens tube, but rather just a set of ridges that the lens cap's ears snap into.  That is when I discovered that you need the FA-DC67A adapter to fit 67mm filters to the SX30/40/50's lens tubes, otherwise there really are no threads to screw anything into.  So my original comment about threads applied to my existing filters - not the 67mm filters.  I have yet to order the new filters or the adapter.
Thanks for asking.
Regards,
Ted
Yes, I finally found (in very small print at the bottom) that I would need an adapter.  I thought, "Well, that's okay - but now my lens cap doesn't fit."  So now I have TWO caps:  One when I'm "just shooting" with no filters, and another one to put on the camera when I have the polarizing filter (or any other filter) on the lens.  It's not the best system (IMHO), but I'm not sure what else to do.
Avatar
