10-29-2014 08:11 PM
I've used the back screen for all my shots and depend on it 90%. I cannot see the same shot when using the viewfinder. Somehow I switched from the screen to the viewfinder and I need to switch it back. I didn't go into the menu to change anything. How do i switch from the viewfinder to the back screen.
12-03-2019 08:19 AM
@Nicof wrote:
This is ridiculous from Canon that nobody has a solution I cannot find any for a EOS 7D
Perhaps articulating your issue will help you find a solution?
12-03-2019 10:32 AM
12-03-2019 10:58 AM
2 things I remember with cameras with a similar problem that has helped, first perform a reset to defaults through the settings menu and second make sure the eyecup on the viewfinder has not shifted up, blocking the light and is seated all the way down.
