06-24-2016 04:06 PM
With the G16 can I set the camer up so that it will capture images every 60 seconds, or some other time interval, until I cancel that operation?
I have looked throuth the manual index for this feature but cannot find any ref.
Can this model camera do this?
Thanks, Euro.
06-24-2016 04:21 PM
Normally, you would use a programmable remote shutter switch known as an intervalometer to do that. If the camera has an input for a remote shutter switch, then you can probably find one for it.
I use a Vello "ShutterBoss II" Timer switch for Canon. Your G16 would use the one with the smaller "sub mini" connector.
06-24-2016 04:46 PM
Your camera accepts a 2.5 mm plug in the remote shutter port. As mentoned there are interval timers that will do what you are asking just find one you like that has a 2.5mm male plug. Most come with several type plugs for different model cameras.
06-24-2016 04:51 PM
Hi Waddizzle,
thanks for the quick response. I was hoping for a setting inside the camera's software. Obviously, I don't have an intervalometer, not anxious to purchase one at this time.
I can keep the shutter deressed and shot continuously, but I was looking for the magic setting so I could mount the camera on my motorcycle and take a picture every minute.
This camera will capture vids also but I wanted to experiment with captured stills.
Thanks
Euro
06-24-2016 04:52 PM
HHi John,
thanks for the reply, I will look into an intervalometer. say that fast three times...
Euro
06-24-2016 04:53 PM
LOL! your welcome
06-24-2016 05:01 PM
Hi Eurocycleguy! Welcome to the Canon Forums and thanks for your post!
Before you invest in a remote take a look at the self timer options built into your camera! You can specify the delay (0-30 seconds) and number of shots (1-10)
Hope this helps and if you do have any questions on this or any other features of the camera please give a call to our award winning US based technical support team and they can answer any questions you have! 1-800-OK-CANON (1-800-652-2666) Monday-Friday: 8:00 am to 12:00 am, Saturday: 10:00 am to 8:00 pm
06-24-2016 05:59 PM
