07-22-2013 12:38 AM
I just got an S110 to replace my S95. I'm still figuring out my way aorund the new camera (despite its commonality with the S95) and one quirk I've noticed is that shots made using the built-in flash are severely underexposed if I use any sort of zoom. I.e., they're only properly exposed at 24mm. This was never an issue with the S95 (assuming the subject was within range of the flash at all focal lengths, of course). Have others had this issue? Is there a setting I'm overlooking? All my tests have been in P mode (or Program AE as the manual calls it). Thanks for you help.
07-22-2013 06:33 PM - edited 07-22-2013 06:57 PM
