04-17-2021 11:23 AM
Just got my SD1100 off the shelf after several years of non use and can't imagine why I stopped using this device. I'm building a house in the country and want to take daily photos of the construction progress. However, I'm not having a lot of luck finding the correct 'setting' in order for my movies to show the GREEN grass and the WHITE blossoms. Although the blues and the grays show up correctly, no other color appears on playback. Even by bright red Jeep looks gray.
Where do I make the adjustment for all the colors?
04-17-2021 05:22 PM
@powpair wrote:
rs-eos Thanks for the reply. I attempted the reset feature per page 175 as suggested, and the reply was "busy". I'll try to find more about that specific reply.
Try removing the memory card. It sounds like it could be going bad. Did the camera ask you to re-enter date and time?
04-17-2021 12:00 PM - edited 04-17-2021 12:01 PM
Try first resetting the camera. See page 175 of this User Manual.
If your images/movies are still incorrect, the camera may be damaged. At that point, call Canon to inquire about a repair.
04-17-2021 02:50 PM
04-17-2021 05:22 PM
06-21-2021 12:18 PM
I am having the same problem and cannot reset to the factory defaults. The method is simple and explained well in the manual but when I select "OK" I get a flashing hand with a strick through it and text that says "busy".
Does anyone have a workaround for this?
Carol
