02-27-2017
02:21 PM
08:39 AM
I am successfully able to transfer photos from my PowerShot G9X to my Google drive when using my wifi connection at home. However, I am now traveling and unable to connect to another wifi source.
I click on Set and it searches access points and I select the correct wifi connection. It then tries to connect to it but eventually says "Set the correct date and time". The date and time are correct, and even if I change it it still does not work. Any suggestions?
01-01-2021 10:57 AM
I have just set up a canon powershot sx530 hs and when I try and use wifi it takes me to authentication and then says set date and time, I have already set this up including time zones, anyone also experianced this and know what to do?
03-26-2024 08:37 AM
Same issue on a G16, has this been resolved yet??
03-28-2024 06:08 PM
Hi guthrie,
Wi-fi issues can happen for a range of reasons. We would be happy to trouble shoot the your PowerShot G16 with you. To do that we will need a little bit more information on what is happening when you try to connect your camera through wifi. Also what device are you trying to connect to, and if you are getting an error message what does it say word for word?
03-28-2024 06:32 PM
Well, i connect to the Wi-Fi local network - "Image Sync" and a local access point. That seems to work fine, although now I see that it also gives a notification "Set Data/Time."
Then any destination I try to connect to (computer, phone, GDrive, ...) all flash their symbol as on the choice menu, and then say: "Set Date/Time", and then reverts to the choose destination menu.
I started a separate thread reporting this...
