09-26-2023
05:36 AM
08:07 AM
I recently bought the Canon G7x iii camera which I intend to use for youtube but I have problems with flickering exposure, even when I lock the exposure. I start filming, lock the exposure, and when I look at the footage after it flickers several times per minute, changing the exposure from one frame to the next. Super annoying. Do you have a solution for this? I'm in Europe and camera is set to PAL. I shoot in 1/50 and 25 fps, and I use a ring light.
Does anybody have a solution for these issues?
09-26-2023 12:11 PM
Try a different type of lighting. If your lighting is cycling on and off as some LED and fluorescent lighting does, it might cause your flickering.
09-26-2023 02:33 PM
This is not it. Two reasons: 1) I've tried different lighting, same thing. 2) The flickering happens two or three times per minute. It's not consistent.
09-26-2023 02:46 PM
Is this how you are locking exposure?
09-26-2023 03:15 PM
Yes
09-26-2023 06:10 PM
Does it happen in sunlight? That is pretty consistent. 8^)
09-27-2023 02:45 AM
Yes, in sunlight also.
