PowerShot G7 X Mark II Black tv lines on screen and in camera
TishyraW
I have a Canon gx7 mark ii. whenever i go to film it’s black tv like lines going through the viewfinder and when i go to look at the videos on my laptop the black lines are still there. No idea how to fix it or where they even came from. please help.
4 REPLIES 4
Tronhard
VIP
VIP
Hi Tishrya:
If the lines are appearing in both, it is possible that the sensor has failed.  Can you take a stills photos of something and see if the lines are still there, please?  By checking that it is impacting both functions it gives us some more detail to work with.
Have you done any updates to the system, changed settings or in any way impacted the camera recently?
cheers, TREVOR
No black lines appear when i take a photo. it’s just when i record on the camera.
That is encouraging.  It suggests the sensor itself is not damaged.  It seems to me that you have some kind of configuration error.  So, I would suggest that you first check that you are using the correct video format and settings.  If they appear to be in order, then the next thing to do is perform a full camera reset.
This is detailed on P 176 of your manual which, if you have not got that, is available from THIS LINK
cheers, TREVOR
Waddizzle
What are you recording?  Indoor lighting might be an issue.  Test it outdoors in bright sunlight.
