11-28-2022
06:26 AM
08:41 AM
After 7 years of use my G16 started asking for the date/time settings each time when I power it up. I suspect it must have an internal backup battery which is depleted but cannot find any instructions on the battery replacement. Any ideas how to solve this issue? Much appreciated
11-28-2022 09:34 AM
Looks like it is a rechargeable battery/super-cap that is not user replaceable:
12-06-2022 09:19 AM
Thank you for the feedback, very helpful. I will visit my nearest Canon service center and hope they have a permanent solution to the problem.
01-02-2024 02:22 PM
Hi, I'm experiencing the same problem. Did the Canon service center help you out with this problem? Do you think that replacing the battery will solve this issue?
01-03-2024 07:29 PM - edited 01-03-2024 07:30 PM
Sigh. Doesn't anyone read manuals? It points out that the G16 has an internal built-in date/time battery (maybe just a capacitor) that is charged from the main battery. When it wears out you have to set the clock every time you turn on the camera. The "permanent" solution would be for Canon to replace the built-in (not user-replaceable) date/time battery. If they can/will do it on this ten-year-old model, that is. And the cost may shock you.
