PowerShot G11 photos won't transfer to computer via USB
JackRoland_528
hi I wanna ask why I used a USB wire to connect my camera to my computer and still can’t get the photos transfer to my computer
I did download EOS Utility to my computer still nothing happened can someone help me please I really want to post my photos
5 REPLIES 5
JackRoland_528
I don’t understand what does it mean in digital photo professional 4 I plug in with my usb wire to my computer and I saw the files said “plug-in printing-> off” why is it off tho and is it because of the off I can’t transfer my photos to my computer?
kvbarkley
What computer and OS?
Np500r3m Samsung I think os is window 10
oh and before my family can transfer photos to this laptop but I don’t know know why can’t
Tronhard
VIP
VIP
Hi Jack and welcome:
If all you want to do is transfer image files to your computer, you don't need any software to do so as long as it has either a built-in or USB connected SD card reader.
Follow this procedure - it is the fastest and more reliable method:
  1. Shut the camera down and remove the SD card
  2. Place said card in a SD card reader, either built-in to your computer or via a USB port. When the card is connected, it should be seen as a removable drive by your file manager.
  3. Access the card, and the folder DCIM, that is where your images are.
  4. Select all the images and copy them across to a location on your computer's hard disc, just as you would any other files.
  5. After checking the files are all there, remove the card (for WIndows machines, you should use the Eject feature which you access by RIGHT+CLICK on the SD card icon).
  6. Return the card to your camera
  7. Turn it on and format the card clean using the camera's Format command.
cheers, TREVOR
normadel
First of all, EOS Utility IS NOT NEEDED just to move files from camera to computer.
Has transfer via USB cable worked at all?
Does the camera show up as a drive in Windows File Explorer?
If it does not, there are three possible reasons:
1 the USB cable is bad.  Try another one
2. the computer USB port is bad. Try another port. Try it on another computer.
3. The Camera's USB  port is bad. If this is the case, I'm afraid your options are limited.
I have always has immediate success in connecting my 10 Canon digital cameras to multiple computers by USB cable.  Have not had to resort to taking out memory cards and putting them into adapters. If the cable method is not working for you, figure out where the problem is.
