PowerShot Elph 360 HS the LCD has gone white, camera 4 years old, can this be fixed?
gun43
4 REPLIES 4
kvbarkley
Do you see the overlays on the screen? Generally all-white is a sensor problem, not an LCD problem. You can try to hook up the HDMI to a tv or monitor to see if it is the LCD or the sensor.
Thank you for the reply, never thought that it might be the sensor.  I did hook up the HDMI to the a TV and a Monitor but it remained white screen.  I did play around with it and it still does take pictures just I can't be sure of what I'm aiming at.  Also, I can still use the HDMI and connect to the computer to down load these pictures.
gun43
kvbarkley
The pictures weren't white?
No, the pictures were normal that is in color and subject matter that was aimed at.  Just the LCD is white.  Otherwise the camera works as normal, strange.
