PowerShot ELPH 360 HS Memory Card error
psaund9860
I have a Powershot 360HS that keeps giving me memory card errors. I have had this camera for 6 years and have had NO trouble with the 50++ SD cards that I have for this unit. Today, ALL my SD cards are getting error messages.
Also, there is no access to the FORMAT option showing up on this camera. What is the solution to this situation?
Start by removing the card from the camera and performing a settings reset. Now remove the battery. Replace the card, and re-insert the battery. If the behavior continues, try a second card. If you receive the error again, the camera will require service or need to be replaced.
Canon Support | Service & Repair | Canon U.S.A., Inc.
1 REPLY 1
