09-19-2022 10:54 PM
I have tried restarting my PC, unplugging the power cord from my PC and Camera, taking out the memory card and reinstalling it, and setting my camera back to default settings. When I turn on my camera, it comes on and acts lik it is not connected to the computer. When I open the program and click import photos from camera, it says 0 even though there are photos on my memory card. I don't know what else to try. The camera was purchased not that long ago. .
09-19-2022 11:20 PM - edited 09-19-2022 11:24 PM
Hi Bes and welcome to the forum.
Sorry to learn you have issues. I would suggest using a different method to transfer your images - this is simpler, faster and more reliable.
1. Turn your camera off
2. Removed the card and insert it into the computer, using either an internal SD card reader, or one that connects via a USB cable - if you don't have one, they are freely available cheaply.
3. When the card is seen by your computer, it will consider it to be a drive, so you can use your File Manager to select and copy the images to wherever you want on your computer's drives.
4. Once copy is complete, check all the files are in the new location.
5. If you are using a Windows computer, use the Eject feature in File manager to allow you to remove the card safely - to do this RIGHT-CLICK on the icon for the SD card and from the popup menu select Eject. You should get a message saying it's ok to do so. If not, close the file manager, then re-open it.
6. Put the card back in your camera and use the camera's format command to format the card - and you're good to go.
I hope this will resolve your issue. It is faster, more reliable and does not depend on draining your camera battery to transfer files.
09-20-2022 04:10 PM
Thank You so much for the advice. I finally found out last night what the problem was. It was the USB Port on my computer. As soon as I tried plugging the camera in to another usb port, it started downloading the photos immediately. Thank You for Your advice and taking the time to tell me. I will try to remember that for the future if I have more problems. .
12-24-2024
04:36 PM
04:40 PM
StevenMOD
Hi Tronhard,
I just read your above reply..............a lot later, huh?........and thought you might be able to help me.
I posted about it this morning, but can't even find my post :).
I have an ELPH 180 and use it on my Win11 Desktop. Recently, it doesn't connect like normal. It does CONNECT to some sort of Win-MS program that I do not like at all.
It works like always on my wife's desktop, using Win7, I think. In all these years I have NEVER had any problem with it working correctly.
I'm thinking something might be wrong with my computer, but two virus programs finds nothing,
Even thinking of "re-installing" Win11, but not sure if I should do that. Just thinking some ":glitch" might get corrected.
I did read your reply, above, but am not interested because of MY USAGE. I sell products on-line, take a picture, edit it then and post it. This current program is totally worthless to me.
Any suggestions? I think this camera is plug and play, but certainly not on my box right now :).
If you'd rather reply by email, it's [Removed per Community Guidelines]
Thanks, so much, Jim
