11-17-2012 08:57 PM
My Canon power shot SX 160 IS is only one month old and I am receiving a "Memory Card Error" Help?
11-17-2012 09:58 PM
Do you low level format the memory card after you transferred the pictures to your computer? If not, do it in the future.
If you have pictures you want to recover from your memory card, use Photorec.
02-13-2013 03:54 AM
Use low capacity memory card in your camera. If you are facing this type of problem then try to format the card and then use a photo recovery software to recover lost photos here is a photo recovery software that can help you. http://www.stellarphotorecoverysoftware.com |
06-22-2013 03:40 PM
First recommend contacting Canon a 1-800-OK-CANON to see if they can help, or if this is covered under your warranty. But if not, please consider the following troubleshooting steps for this problem:
