12-25-2025 03:54 PM
I just bought a Canon EOS R-7. The firmware version is 1.6.0. I downloaded the firmware version 1.7.1, unzipped it, and copied it onto the formatted memory card at the highest level where the folders live. I am on a Windows 11 computer and used a transcend card reader with the formatted card that was formatted in the camera. I followed the directions on the Canon website and the camera seemed to find the new firmware. However, when I get to the Update Firmware screen, the OK is grayed out. Up to this point, everything looked just the instructions said they should.
Any idea what I did wrong? Any other information I need to put here to help with troubleshooting?
Thank you,
Marcy
12-25-2025 06:45 PM
Please use the quick control dial on the back of the camera. Rotate it to the right 12>3 to move the focus from cancel to ok. Then press the set button. 😉
12-25-2025 04:06 PM
Have you tried to tap ok? Or use the controls to move focus to that control.
12-25-2025 05:28 PM
The touchscreen will not work.
12-25-2025 06:45 PM
01-05-2026 11:07 AM
This worked. Thank you for your help.
01-05-2026 12:28 PM
Thanks Marcyb,
Enjoy the R7.
