Memory Card Error - Canon Powershot SD30
jaoperalta
I have a Canon powershot sd30 and im not sure how to fix the “memory card error” message that keeps popping up, ive tried the tricks on how to fix it and none of it worked. Anyone know the problem or even know what the right memory card to use? thanks
According to the User Manual (see page 117), the camera came with an "MMC-16M" card and can additionally use "SDC-128M" or "SDC-512MSH" cards.  From some searching, I have only found off-brand cards on Amazon.  B&H Photo doesn't carry these cards at all.
So even though I state to always avoid Amazon for memory card purchases, in this specific case, due to the age of the card technology, see if you can get a replacement card and try it out.
Note that your camera has been retired by Canon, so if you're dealing with a hardware issue, they will no longer repair it.  May also be difficult to find any camera repair shop that would still be repairing these.
Ricky
5 REPLIES 5
Greetings ,
Can you tell us what error message you are receiving?
You've "tried all the tricks"... And what might those be?
Memory card type. You can use a full-size memory card 32 GB or less.  A reputable brand SanDisk, Lexar etc. You can check your manual for recommended cards.
The  message I keep receiving is just “memory card error” and when I slide to video mode it says “memory card error card locked” though the memory card is unlocked it’s annoying me that I don't know how to fix it and “those tricks” were the ones I looked up online like unlocking the memory card, formatting it, etc. Ive tried the full size memory cards and it didnt work on this old canon powershot. It says on the manual a 16 MB mmc card. Not sure where that’s available and if anyone knows any more memory cards to use on this powershot
Ricky
SammyGitonga007
Hi
Can I access my files on a memory card reader after the camera says it cannot read it?
Canon supplied 16 Megabyte SD cards with their digital cameras back then, more as a courtesy than because they were useful. This is tiny.  Only holds a half a dozen images. By no means were the cameras limited to cards this small. You can't buy cards this small.
Nowadays the smallest SD cards for sale new are 16 GIGABYTES, which is 1000 times bigger than 16 MB. You can get them for 10 bucks. Just be sure to get a full-size, NOT a Micro card.
