07-20-2016 08:43 PM
Do modern powershot camers have the ability to be controlled via a smartphone? What range can I expect when doing this?
Has anyone tried this and whats worked for you? CamRanger system is too expensive. Please advise.
07-21-2016 05:04 PM - edited 07-21-2016 05:07 PM
@PhotosbyMJ wrote:Do modern powershot camers have the ability to be controlled via a smartphone?
The Canon G1X Mk II would be ideal for this. It is WiFi capable and with a sensor size between M4/3 and APS-C it has fantastic image quality.
I don't have a Mk II, but, my G1X has no shutter sound. There is some sound from the lens focusing and nothing else.
07-21-2016 02:11 AM - edited 07-21-2016 02:12 AM
Don't have an answer to your question, but have one of my own. Have you talked this over with the Pastor? He may have something to say about this.
07-21-2016 06:27 AM
07-21-2016 08:25 AM
@PhotosbyMJ wrote:
Asking this will be a factor in my research on this idea. Respecting the officiants rules is a top priority for me. I'm simply exploring the concept at this point. I think offering photos like this would be a great value for my clients (where I'm permitted to use a system like this of course).
Camera noise from the shutter activating should be high on your list of concerns, too.
07-21-2016 05:01 PM
@Waddizzle wrote:
@PhotosbyMJ wrote:
Asking this will be a factor in my research on this idea. Respecting the officiants rules is a top priority for me. I'm simply exploring the concept at this point. I think offering photos like this would be a great value for my clients (where I'm permitted to use a system like this of course).Camera noise from the shutter activating should be high on your list of concerns, too.
Most Powershot cameras use an electronic shutter, and with the simulated shutter noise turned off are virtually silent.
07-21-2016 05:47 AM - edited 07-21-2016 05:48 AM
The PowerShot category covers a wide range of cameras. The answer would be "some yes".
Go here and search for features, cost, etc.
http://shop.usa.canon.com/shop/en/catalog/cameras
07-22-2016 12:05 PM
07-22-2016 12:23 PM
@PhotosbyMJ wrote:
I'm checking into renting this for the wedding. My biggest concern is the wi-fi range of operating the camera....how far can I (realistically) be away from it to control it with my smartphone?
Wireless range is impacted by a number of factors other WiFi on the same channel, obstructions, electrical interference, etc.
I think you could expect a minimum of about 30' worse case and a maximum of 100' best case. The only way to be sure is to test it.
