09-25-2013 07:02 PM
Hello Canon Users,
I have a question in regards to my Canon Powershot ELPH 330 HS. Most of the time, I use this camera sitting down and talking into it. The Anti-Shake feature is excellent for taking video when moving around, but when sitting down, the following happens. When I move, the background moves a bit making the video very unstable and it looks horrible. Is there a way to disable the anti shake/image stability feature? Any help is much appreciated. Thank you!
09-25-2013 07:16 PM
Press <MENU>, then choose [IS SETTING] = OFF.
Page 82 of your manual.
09-25-2013 07:31 PM
Umm. It appears I don't have a page 82 in my manual... I have up to page 80, then after that is the spanish version. Also, The IS Mode = Off. I just tested this and still when I move, and the camera is still, the background moves slightly. Any idea how to fix this?
09-25-2013 08:21 PM
Is this IS mode only for taking pictures? Or does this disable IS mode for video too?
09-26-2013 12:19 AM
I'm not sure about that on your camera, if your camera is on stable surface (table or tripod), does it shake slightly?
09-26-2013 12:46 PM - edited 09-26-2013 12:47 PM
See, what happens is, I have my camera on a stable surface (my tripod), Then, when I move, for example moving my hands or my body slightly, the background shakes a little bit. I don't know why, but I'm assuming it has something to do with the stabilization. If I stay perfectly still, the background will not move, and everything will be fine. But even the slightest hand gestures or body movement makes the background shake.
09-27-2013 02:34 PM - edited 09-27-2013 02:35 PM
Even without touching the camera? I've not heard or read anywhere about this. Good luck, let us know if you figure out the reason.
09-27-2013 08:26 PM - edited 09-27-2013 08:28 PM
I really didn't want to put my face on this forum lol. But, for the sake of y'all seeing what I'm dealing with here. This is a short few second gif of me talking into the camera. Note, the camera is stationed on a tripod. If I stay perfectly still, the background will not move, because I am not moving. But when I move, the background moves. Here:
http://www.gifsforum.com/images/gif/other/grand/3407f59ea40409d9c4754a670226d1c3.gif
09-27-2013 08:31 PM
I don't know what the problem is 😕 It's kinda upsetting that this happens because I invested some money into this decent camera. I hope someone has the fix for this.
11-07-2013 05:05 PM - edited 11-07-2013 05:07 PM
Even though this was from a while ago, I'm going to resurface the issue to see if anyone new can solve this.
Still, if I place the camera on a flat, stable surface, I sit in front of the camera, as I move around, or make gestures with my hands, or move my head, the background shakes a bit and its very noticable. It looks extremely unprofessional when I play it back or I need to produce a video for something.
If anyone has a solution, please reply. I already tried enabling/disabling the anti-shake feature (the image stablizer), but im pretty sure it only applies to when taking a picture.
Thank you.
