08-12-2024 07:40 AM
Hi everyone!
my flash has randomly stopped working… even when I have “flash on” there is no flash. I’ve reset the camera, charged the battery.. I’m not sure what else to do.
when I have the “flash on” there is a flash sign at the bottom of the camera that appears then disappears (flickering)… is this indicating anything? Attached an image
please help!! 😞 the camera is only a month old and everything else is working fine, not sure why the flash isn’t.
08-22-2024 04:12 PM
I’m having the same issue!
12-13-2024 12:59 PM
I am having the same problem.
12-17-2024 05:22 PM
Greetings madelineelizabe,
We recommend on resetting the camera to factory default settings to see if this helps resolve the issue. Please also check to ensure that there is no debris on the front of the flash and no obstructions around the flash assembly to where it extends fully when brought up.
In case the issue persists where the flash is not firing, then we recommend on sending it to our repair facility.
Items purchased directly from Canon USA or from an Authorized Canon Dealer do include a one-year warranty if the item was purchased less than a year ago. You may view a list of Authorized Canon Dealers by clicking on the following link. I would recommend including a copy of your Proof of Purchase when sending in your item for the facility to review for any in-warranty service or repair.
https://www.usa.canon.com/internet/portal/us/home/contactus/where-to-buy/authorized-dealers
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
