02-02-2021 02:32 PM - edited 02-02-2021 02:32 PM
About a month and a half ago i got raindrops on the lens of my PowerShot SX740 HS. They left a mark after they dried. I tried cleaning it off with a microfiber cloth. That didn't work. I also used a blower to get dust off before i used the cloth. I then applied some Bower lens cleaning liquid to the microfiber cloth. That did the trick. I know that one should not use glasses cleaning solution on camera lenses. I'm wondering if this applies to the lens of the PowerShot SX740 HS, because i have applied glasses cleaning solution that contains Isopropanol on the same cloth I used for the camera lens. Although i did not use it to clean the camera lens. I'm wondering if this would damage the lens,
02-10-2021 01:42 AM
Hi there,
These newer lenses are going to be more resilient when it comes to things like this, but its still a good idea to avoid as much unecessary contact with other solvents as possible. In your case I would not worry too much about this one instance, but keeping a clean lens cleaning cloth on hand to wipe the lens before anything solidifies on it would be best.
