07-29-2017 10:38 PM - edited 07-29-2017 10:51 PM
Hi, I just bought a canon s110, and everything works great except for when the lens gets anywhere near a light. When the camera is pointing at any bit of light, it has a really bad lens flare. I don't know if this is a common problem, I tried cleaning it with my other camera cleaning kit, but nothing changed. Any help?
07-30-2017 02:17 AM
This doesn't look like lens flare...are you sure you didn't accidentally activate some sort of in-camera special effects? You might want to reset the camera to factory defaults...just in case...
07-30-2017 03:48 AM - edited 07-30-2017 03:49 AM
I find the fact that the effect is at an angle to be rather curious. Are you using a lens filter of some kind?
07-30-2017 07:55 AM
Thanks for the reply, I also factory reset the camera and it still does the same thing.
07-30-2017 07:56 AM
The camera does this at any angle, there's no effect, and no lens filter.
07-30-2017 04:25 PM
Try to change the settings in light metering.
Press Func/set-light metering and select spot. There are three options give a try evaluative.
07-31-2017 03:36 AM
Try cleaning the glass on the lens. It kind of looks like maybe it has a residue of some kind on it which is doing funny things with thelights.
07-31-2017 05:36 PM
I looked at the EXIF data for your pictures and I think I found your problem...
Camera Maker: Canon
Camera Model: Canon PowerShot S110
Image Date: 2017-08-29 20:40:20 (no TZ)
Focal Length: 7.488mm
Aperture: ƒ/2.8
Exposure Time: 0.017 s (1/60)
ISO equiv: 640
Exposure Bias: none
Metering Mode: Matrix
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
Your camera is taking photos ONE MONTH INTO THE FUTURE!
But before you have it repaired I need you to take some sample shots for me of some winning lottery tickets. Just for research purposes, you understand. ![]()
But seriously, if cleaning the front of the lens doesn't cure this problem there may a coating of something on one of the inner lens elements. And that's a cleaning job for someone else to tackle.
