Canon SX110is Terrible Pictures (Need Help)
rftech
I am getting terrible pictures. I went through all of the settings several times and it still takes slightly out of focus and sometimes dim or slightly washed out pictures.
Is there a firmware update available ?
Frank
I think I figured out why some of the pictures were slightly out and slightly out of focus.
The ISO setting was set to 100 which caused a slower shutter speed and by not having a polarization filter some of the pictures had a slightly washed out look.
I should have know better from previous experience to use a slightly higher ISO setting.
Thank you for trying to help.
3 REPLIES 3
rs-eos
Can you post a couple examples? Especially if they also contain the camera settings used?  It could very well be slow shutter speed.  But all we can do is guess without seeing actual data.
Ricky
jrhoffman75
In addition to posting examples, what happens if you set the camera to the auto setting and take a photo outside at midday?
