05-15-2021 11:30 AM - edited 05-15-2021 11:31 AM
I bought a non-working G15 off of Ebay about a month ago in hopes of easily fixing it, the display didn't work, so I replaced the display and it still doesn't work. After that, I removed the mainboard and cleaned it with rubbing alcohol hoping that the board's corrosion was causing it; Nope. This time, it wouldn't turn on unless I held the power button and the display still didn't work. I took it apart again and reseated the internal CMOS battery and this time when I tried to turn it on, nothing happened. I ordered a new mainboard and put it in and it still doesn't do anything when I try to turn it on. I'm thinking the flash board may be dead or the power button somehow doesn't work. Thoughts? I'm gonna pull all of my hair out.
05-15-2021 12:11 PM
Why not save your money and apply to either a new or refurbished/used item from a reputable source (e.g. B&H)?
05-15-2021 12:32 PM
The list of what was originally wrong in addition to what the new symptoms are is pretty long. (display, various connectors, motherboard, battery box, DC board, etc, etc) I think you got the best advice, cut your losses now and let that camera R.I.P.
The upside is you did get what you paid for on eBay, a non-working camera.
08-03-2026 08:53 PM
Hello, it's been years since you typed this comment, but I'd like to know, was your screen removable? like completely? the canon PowerShot g15 I have has the smaller ribbon cable connected to a small white box, it does not look like a tab ribbon connector and I am having a hard time trying to disconnect it without having to unsolder. Do you remember how you disconnected it?
