02-15-2018 04:07 PM
This camera is causing me "conniptions". It took me a week to fix the problem of being unable to upload photos via WIFI and now this! I was, prior to having WIFI issues, uploading my photos to my computer via the USB cable. I had no issues. Then I had WIFI issues when I traveled which I had difficulty correcting. I eventually fixed the issue. However, I then found I could no longer upload my photos using the USB cable. In fact I thought the cable must be faulty so I ordered a new one. Same problem. Yesterday I eventually started up an old laptop and had no problem uploading my photos from my camera to the laptop, using either of the two cables I now own. However, I cannot get the photos uploaded to my desktop, even though I was doing so for several months prior to the WIFI issue. I have tried everything I can think of and looked at all the help files, and still unable to upload. Please help!!!
I might add when I had the WIFI issue and contacted Canon I found the "support" unhelpful. They clearly didn't read my emails as they told me things I had already tried and mentioned in the emails, and when I tried to call I got a constantly busy response and never got to a customer service person. I eventually did correct the problem myself but it took over a week. I have owned Canon cameras for the past 25yrs and never had issues. I own an EOS which I use locally but bought this small camera for travel, and it is giving me a lot of issues. Any advice on fixing this issue will be appreciated.
02-15-2018 05:20 PM
Turn off wifi when you use the cable.
02-16-2018 04:44 PM
I do not see how to turn Wifi completely off. I turned the NFC off. Made no difference. However, I don't see why this would matter as I wasn't doing this previously. I had Wifi operational AND could still upload photos so what is different? When I click on the "upload" from camera in my photos file, that I used prior to 2 weeks ago, it says it can't find anything to upload. There are more than 700 photos on the camera. Plus it uploads to my laptop. It is just confusing.
02-17-2018 03:17 PM
What is the desktop computer OS?
Need to clarify that you mentioned NFC off - you want transfer to cell phone via usb?
Do you have SD card reader in your desktop computer?
You have mentioned that is working before and now no more using usb cable transfer to desktop computer?
02-17-2018 06:00 PM
@Nagal wrote:I do not see how to turn Wifi completely off. I turned the NFC off. Made no difference. However, I don't see why this would matter as I wasn't doing this previously. I had Wifi operational AND could still upload photos so what is different? When I click on the "upload" from camera in my photos file, that I used prior to 2 weeks ago, it says it can't find anything to upload. There are more than 700 photos on the camera. Plus it uploads to my laptop. It is just confusing.
The camera is not smart enough to know use Wi-Fi or USB by itself. You must tell it which method to use, one or the other. If you believe that the camera once figured it out by itself, you are mistaken. It was just coincidence that worked in your favor.
02-18-2018 09:05 AM
"The camera is not smart enough" ...
The questions was not answered and no idea how to go on, incomplete info will give incomplete solution. Remember that the operator operates the camera/computer and not the camera/computer has to think by itselt.
02-18-2018 09:51 AM
Still no_one has explained how to turn Wifi off. I have gone through all the menu items and do not see an "on/off" on wifi. Could someone explain it step by step?
02-19-2018 07:43 AM
... explained how to turn Wifi off...
Select any method you want if you are using windows 10:
1) At the bottom right screen notification area click on airplane icon and click wifi to off the function.
2) Click on windows logo: type in internet connection troubleshooting,at network and sharing center, change adapter settings, see at upper left- wifi can be off.
05-24-2018 05:56 PM
Hi Nagal,
Thanks for posting.
With regard to your camera's Wi-Fi setting, there's no need to turn it off. This is an issue for a few EOS Digital SLR cameras.
If you're still unable to transfer via USB, from your description, it sounds like the driver for your camera has become corrupted and needs to be removed and reinstalled.
Which operating system do you have on your computer?
12-05-2018 09:42 PM
Okay, I have looked at all the replies above and not had any luck. I am using Windows 10 64 bit. I have been able to transfer from the camera to the computer using a USB cable before, but cannot do so now. Plugging in the camera and turning it on results in nothing. I have rebooted both camera and computer multiple times. I have made sure the micro USB is plugged in fully. I've turned off every WiFi option on the camera. This was working fine with this cable just a few weeks ago. If the driver in Windows needs to be replaced, I need instructions on how to do that, which driver, where to find it, how to uninstall it and how to locate another copy or more recent copy. I have never had this much trouble with any other camera I have ever owned. This is about to turn me off of Canon as tech support is not helpful at all. Please help!
Thanks!
John
